Discuss 4.3 kw oven would you fit on to a ring main in the Australia area at ElectriciansForums.net
M
marty1234
hi guys would any off use guys connect a 4.3 kw oven on to a ring main if it was not possible to run in a new supply for this appliance let know what you think
In a word no.
Any cooking appliance 2kw or over should have its own circuit.
Just out of interest, how would you propose connecting it to the RFC?
hi mate just asking the question i was in a house to day doing some work and noticed this was the way the spark wired it . he has fitted a 20amp double pole switch and marked it up as 16amps .i would have ran in a new supply my self very hard job but i think a better one
hi 4.3 kw = 19amps and as jason pointed out 2kw requires a dedicated circuit
plus manfacturers instruction would state something along them lines
Apart from the rating of the cooker. It's annoying to have to switch the ring off to change the cooker in the future. Added to which if the cable to the cooker is buried, if there is ever no cooker, there is a potential for an exposed cable to go live when the ring is on.
Reply to 4.3 kw oven would you fit on to a ring main in the Australia area at ElectriciansForums.net
Hi, I'm installing a Hoover oven and would like a little help please. The oven code is HOC3158IN. The oven manual states "The power cable must...
Hi guys. Having a weird problem in a house that has suddenly happened. One half of the ring main has 240ish volts (fluctuates of course), and...
Good evening. Currently sorting out my girlfriend’s flat for rent. I’ve found all sorts of bad electrical work. Can anyone advise if this is an...
Hi guys I am looking to add 4 additional sockets for a room that is being converted for a bed ridden person. The room at present has no sockets in...
Hi All, Thank you for your previous advice - it resulted in us replacing our precious Smeg range with a Hotpoint; however we now have a new issue...
