Discuss 4 Pole RCD/TD replacement in the The Welcome Forum area at ElectriciansForums.net
Money is no substitute for good practice and safety. We're not stupid, OP, we all know that Crabtree is really expensive and Protek really cheap.
to the OP. would you run your ferrari on paraffin?
Thanks but are you inferring that makes such as Protek and Chint don't comply with the BS marked on them if so don't you think these companies would be prosecuted for selling dangerous devices,do you know of any cases where they have been found to be faultyâť“
Makes like that are prone to failure and of very poor quality.
But even if you chose a good quality brand like Schneider or MEM it still should not be fitted in to a Crabtree board , it should be Crabtree kit.
that may not be the issue. if you fit a non=crabtree component and there's a fault with the DB unrelated to what you've done, crabtree can disclaim responsibility as you have fitted non-genuine parts in contravention of their instructions.
Just swap the whole lot for ABB and when it goes up in smoke for no reason apart from a obvious manufactures fault on the internal buss bar , they can then take over 8 months and counting to come back with anything other than we will look at it , but it will have been operators error anyway !
So when it comes to mixing makes in the same board , you will definitely be on your own if a fault arises .
Reply to 4 Pole RCD/TD replacement in the The Welcome Forum area at ElectriciansForums.net
Hi all, I needed to replace an MCB for an electric shower with a different rating, it's an older Loadstar consumer unit, and crabtree told me word...
Hi everyone, I have been asked to pull in some new 3 phase supplies for 7 new welders which do not require a neutral connection. The client has...
Hello Need to replace a distribution board in the next few weeks to allow for more circuits to be installed in January. Existing is a TT system...
Hi everyone, Quick question can you fit an RCD without any neutral connections? If I have a 3 pole circuit breaker which has all 3 poles...
Hello - hope someone can advise please. I have a recently purchased second hand Myford lathe which has a 3-phase inverter (Siemens Micromaster...
