need some advice really
bee asked to wire in a timer to a swimming pool heater as it is on constant run, which I explained is how they are supposed to run.
does anyone know of a single phase 230v contactor of AV-3 type I can use with a simple manual clock timer switch, or suggest any other ideas of how i may wire it. im pretty sure I cant just use2 poles of a 3pole contactor!?
currently someone has wired it direct to a type c 32A breaker, the equipment label requires a 40A beaker in any case.
