Discuss 7A fused plug in the UK Electrical Forum area at ElectriciansForums.net
pc1966
While visiting some friends down south I noticed they still had the cardboard wiring info on their coffee maker, so removed it as not for final use. What was curious is it specifies a 7A fuse, and while I have seen and used some odd ones before (e.g. 1A, 10A) this first time I have seen on fitted to a mass market product!
TL;DR anyone seen unusual fuses before?
Also I always remove them, but I don't see that said on the cardboard. My assumption is they are both a fire hazard (more flammable than the plug or socket cardboard) as well as a shock hazard as when damp massively reducing the creepage distance.
Any got a definitive statement either way? To remove, or not to remove...
Mainly because it stops the plug from being fully inserted into the socket-outlet. TBH it makes no odds as the design of both plug and socket allow for a margin of error.
I always remove them and agree that there should be advice to do so for the two reasons you mention. I have actually seen a flashover caused or assisted by the reduced creepage distance; I kept the plug at the time but not sure if I still have it. I really don't see the point of supplying the information on a pre-installed plug, but some of these things are carry-overs now rather out of place like the inclusion of old colours. And the customary blurb 'This new-fangled square pin plug might not fit the sockets in your house...' or however it goes. I have not seen appliances supplied with 7A fuses either, and wonder what their intention was, other than 'because we can.'
Curiously the only commercial product I can recall specifying 7A BS1362 fuses was not fitted with a BS1363 plug. The fuses were used in 1" x 0.25" panelmount fuseholders as channel fuses in Green Ginger Micropack lighting dimmers in the 1980s. The anomaly was that the channels were rated at 2.5kW, I believe the intention was for the fuse to be deliberately overrun so as to provide the lowest possible I²t to protect the triacs. The BTA40s turned out to be pretty tough and would easily eat a 10A without damage, so I recall that the later units specified a 10A fuse instead. Some competing products that used BTA25s did not fare so well with 10A fuses and the triacs were much more prone to failure in the event of a short-circuit.
I wonder if it was bought before the requirement to have factory fitted plugs on consumer goods.
It looked like the coffee maker was probably only a couple of years old at most.
I'm wondering if it was some sort of promotional / review model so not a mass-production style of moulded plug?
It faintly amuses me when I find an item with a PAT test sticker and there is still the card on the plug. Clearly connections not checked and correct fuse for flex not checked!
Why ? IME the cards have holes so you don't need to remove it to access the cover and cord grip screws.
But that's not what you said. You suggested that the presence of the card meant the plug can't have been checked which is orthoganol to whether leaving the card is a fail or not.
I would always remove the card, orthoganal or not. There are no right angles here, just an inversion of the diagram, but the card should be removed as damp is not your friend, and some cheap sockets need as much penetration as possible. Indeed, i saw a plug the other day that was so cheaply made that the socket-facing surface was distinctly quaquaversal, so proper contact was doubtful in the extreme.
I don't think it's universally true that the cards have holes in them, and I concede I am going back around 10 years and I didn't make that clear. Here is one example:
What’s it got to do with being 8-sided????
anyway, card off- check fuse- replace card… what’s difficult?
Nah…. Throw the card away. It’s pointless. Last example, who’s going to measure how much insulation and sheath to strip off? To the millimetre?
Comment
“looks like it was installed by a knob skull”
Yep, that would sum it up...
Or maybe....as it is the house of a highly educated GP...
"While originally competently installed the trajectory of creative and poorly executed extensions and modifications have been somewhat orthogonal to BS7671 ever since."
orthoganol
Anyone with a smattering of organic chemistry will recognise the orthaganols. They are like regular aliphatic alcohols but having been invented by electricians they have unusual bond angles held in place by cable ties. The simplest is:
Reply to 7A fused plug in the UK Electrical Forum area at ElectriciansForums.net
Hi all, Been browsing these forums for a while, always great to learn a new way to skin the same cat. Anyway, cut a long story short, was an...
Hello My dear old mother tried to clean the tiles in our utility room by using a damp rag and I think some water may have dripped into our plug...
4K
  • Locked
5K
Hi, Have normal fused immersion heater switch. I would like to add a smart wifi switch to it so when my Solar is producing over 3k spare, going...
Posted this to the DIY section since I'm not a business or employee in this matter but it feels more appropriate (and might actually get...
