Discuss A Bad 3-Way Switch Can Cause Failure of the Other? in the Lighting Forum area at ElectriciansForums.net
short answer, yes it can.
check it out with a volt meter and you will know.
YES ! FOR SURE. 3 way switchs are wired differantly to normal switchs, and if you look at the circuit for a little while, you will understand why !
Thanks for the replies.
I was told that by an electrician's assistant and to wanted to verify.
Is it always the case that if one 3-way is bad another won't work? And do switches have a life span?
Thanks again. Really appreciate your time.
Reply to A Bad 3-Way Switch Can Cause Failure of the Other? in the Lighting Forum area at ElectriciansForums.net
I genuinely can't find a 3 gang 3 way black smart light switch - any ideas where I can get one from? Seems to be hard to get hold of?
Hi, I have two 3-way toggle switches by the opposite sides in my garage. Is it possible to replace both of them with motion sensors? Thank you. .grig
Hi, I’m looking to install 3 meross smart switches for 3 lights: entrance switch: only 1 gang but 3 way switch bedroom switch: 2 gang (1 is 1...
I can't seem to find the right answer for a smart switch installation for a light that has THREE switches. There's conflicting information, and...
