- Reaction score
- 5,610
Afternoon all..
I am about to lay approx 30m's of 3 core 2.5mm of SWA (with approx x2 45degree bends and x2 (gentle) 90degree bends where it will protrude, and perhaps 10m of 19 core 2.5mm swa with x2 (gentle) 90 degree bends. These are going in separate trenches.
I realise there is no requirement to put them in conduit but I'd like to just in case they ever need replacing or perhaps an addition needs to be added.
I have a few questions :
1. What size flexible conduit would I need for the above? I do not have the size (diameter) of the cable to hand.. sorry!
2. Is this going to be a struggle or will it pull through fairly ok (with one person feeding and one at other end)?
3. Is there a type of flexible conduit that is not perforated on the inside which would make things much easier? Or perhaps a type of flexible conduit that someone would recommend? I don’t want to use an expensive one (kopex etc) as this is not to afford mechanical protection it is solely to help with future maintenance or design change.
4. I never seem to see the ends of conduit where they come out of the ground covered, so water can get in and will just stay lying inside the conduit surrounding the cable. Is this a concern? I realise the SWA is waterproof, but I am unsure if it is designed to be constantly immersed in water.
Many thanks..
Many thanks..
