Discuss approved document legal requirements in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
R
rob69
Hi All, I Know that Approved documents are a guide to meeting building regs! I have a customer who wants a rewire but does not want the kitchen or bathroom vent fans fitted. I am correct in assuming that he does not have a choice ,the same as any Approved documents they have all got to be complied with????
as it's not a new build, get on with it and note on the cert. that fans have not been fitted at customer's request, but that you recommend them.
If work other than the rewire in the rooms came under Building control then they would most likely want the fans fitted.
As it's only a rewire it won't involve a B.C visit.
Hi Snowhead , sorry but your reply is not very clear ! Surely a rewire requires notification (inc DB) and it should also bring the premises up to the current regs. Anybody got any views please!!!!!
Yes a rewire requires notification. Yes it should be installed to current regs, BS7671 that is. There is nothing in BS7671 that requires ventilation to be installed during a rewire. Ventilation falls under the building regs part F, which only applies to new builds and new build areas such as extensions.
Yes a rewire requires notification. Yes it should be installed to current regs, BS7671 that is. There is nothing in BS7671 that requires ventilation to be installed during a rewire. Ventilation falls under the building regs part F, which only applies to new builds and new build areas such as extensions.[/QUOTE
SPOT ON. and there is also no requirement to fit smoke detectors on a rewire, either, but most of us do as a matter of course.
Reply to approved document legal requirements in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
A recent thread on the suitability of a cable supplied preinstalled on a manufactured floodlight/pump had me wondering a few things. Over the...
Good day. First time poster. We recently had an electrician perform the EICR, as this is a newly purchased property I thought'd I would have the...
Hi, I've just had some electrical work completed in the bathroom; I've recently refurbished the bathroom, replacing the old electric shower with...
8K
HI There, I would be grateful if you could help me, I have a very long duct between the bathroom and extractor outlet vent and for sometime, the...
Hi guys, I've gotten AI to write up a terms and conditions for my company and then went through it with AI and tweaked it to make it sound a...
