phoenixfire902
- Reaction score
- 0
How do I know if i will need a 240 V or a 120 V? Wiring my own home for the first time and i am trying not to overwhelm myself with research but also educate myself. I plan to do 100% of the wiring myself and I wanted to know how i will know if i am using 240 or 120 and if that is based on my appliances, how will i know with existing appliances what i will need? I assume most people dont check major appliances electrical compatibility before buying them so how will i know things like washer, dryer, fridge will all work? OR on the flipside if the appliances i already have will be able to wire right into my box? FOR EX: what if i have a 120 v fridge but another major appliance is needing a 240? Is there some sort of convert I can use to double/half my volts to make everything wire in safely or what? Prefer to not mix if it is not safe or recommended to avoid fire hizards! I plan to turn a shed into a tiny house and i am wanting to learn up on what ill need. Also, how does the distance affect the guage? It will be a tiny home so i assume i wont have to worry about upping the guage for distance. How set in stone is the guage? Is it okay if i accidently run a guage one size up or down to avoid buying another wire size or is that a big nono? And final question, what is the denominator over some of these wire gauges example (12/3, 12/2)?
