Discuss Best method for smokies in the UK Electrical Forum area at ElectriciansForums.net
N
NadHuh
Ok let's try to do this without getting any "Get of you DIYer your not getting any answers from us!" I am not a DIYer.
So I was wondering how people normally connect there smoke alarms,
Do you connect the twin and earths in a junction box.
Or do you use a chock box or do you just get one of those adapter plate that gives you space to put a connector block in.
And which is the best method?
If you're using wired smokes then try counting the number of conductors required between each one and then try and work out how on earth you'd do it with t&e..
Yeah call me , I'm back in action 2nd jan. oj.You obviously haven't installed any before . Read a manual online and come back and go ahhhhhhh I see. Ho ho. Ho. I'm santa tonight bring al presents out and spank the rain deer .
No bones about it but the smokies as you call them if they are decent ones you connect the wire in to them I hate that cheap crap with the leads as for the fishes smoke them with whiskey barrel wood shavings and if you ain't got them wired by now then you will just have to figure out the oven timer cos sparks all over are now on holiday not worrying if your turkey burns or not hehehe
So come clean with us. I note on an earlier post you suggest you are a 1st year apprentice. Please tell me you're not endeavouring to to a full rewire already??
Wrong thread
Is that so >
If thats the case the plot thickens
A question was asked
I have never really understood why you need a 3rd core when wiring smokes, live, neutal and earth i get, but why do you need a switch wire exactly,
what is its job ?
Your answer
Even I knew this and I'm a first year apprentice
You know that a third core is required and you then write this
The wiring is already done in this install as I have said in the previous posts so the electrician who done this obviously run out of 3 core so his used 2 sets of twins and earth! Now can we get back to the question I asked?
i connect the wiring within the pattress extension boxes underneath the smokes.
this is my last , and possibly only , sensible post of the nite. :)
so the so called electrician who ran out of 3 core should be sacked and replaced by a spark who knows what he's doing. did he run out of earth sleeving , so replace with a bit of tape? run out of screws so a couple of nails will do. FFS. use the right gear for the job or leave it to someone who can.
stop giving away my trade secrets.
;-D
Reply to Best method for smokies in the UK Electrical Forum area at ElectriciansForums.net
Hi, I'm looking to install a new bathroom extractor fan in my bathroom as I have a windowless bathroom and the current one I have installed in...
Hi Everyone, Sorry in advance if this is a silly question. There is a junction box in my mother's kitchen, on the wall above her kitchen...
Hi I've been planning to fit an outdoor junction box at the front of my house to hide a large brickwork hole and properly house the wiring...
Hi all, Just wondering what the general situation is with other people on smaller jobs, do you give a quote or estimate to the client before you...
Hi All. What is the best/preferred method when connecting 20mm conduit to a back box of a socket on an outside wall ? I am connecting a BG...
