Discuss Bit stuck here! in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Goody
Been to a flat to test prior to changing the consumer unit. Two rings and two light circuits but none of them has an earth cable, just phase and neutral but Zs at the sockets are good. It’s a TNS system with Ze of 0.26 ohms. How do I go about finding R1+R2 for the rings in this situation? Thanks!
is it wired in steel conduit, using the conduit as cpc?
Yes, I can see some section but not that visible under the metal boxes embedded in the wall. I am sure, the steel conduit should be responsible for such a nice Zs values.
Reply to Bit stuck here! in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Hi, while carrying out an EICR at a farm cottage on Friday i came up against a problem early on. Whilst measuring the Ze the reading i obtained...
I have been asked to look at this report as the customer has been given (in their words) 'A very high quote plus VAT'. It doesn't look well...
Hi, I have lifetime experience (50+ years) in United States with basic knowledge of split phase 120/240 volts replacing wall switches and...
