Discuss Board change? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi,
Recently been to a property that requires a board change but got no main switch. Usually the service fuse has no tag (lol) so i simply remove fuse crack on an re insert.
today i came across one were it had a big steel covering. On the PIR it had been picked up as "unable to access supply fuse"
What do you guys do in this instance?
edited due to the fact that the OP is not competent.
Hi,
Get the DNO to come and fit an isolator
Hi,
I suggest you call an Electrician Paul, I feel you may be struggling a little mate due to your last few posts made of the forum, you seem a little unsure and you may drop a major clanger if you are not careful.
Reply to Board change? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi I'm looking for some advice for adding a time delay on my parent's shower room fan. My parents had a section of their garage converted into a...
Hello all, Looking for help here as I've come across a strange call-out today. Bare with me here: Got a call from a customer saying they had...
Hi all, I am looking for some advice regarding old rewireable (3036) fuse boards in regards to additions and alterations. I am an electrician and...
4K
