Discuss Cable help in the FreeSat, Sky, VirginMedia Forum area at ElectriciansForums.net
K
keefy
I am wiring a house that wants HD freesat. The TV guy who is doing the job for the customer is away and I can't contact him. I need to finish the first fix as I said I will do it as he was away!
My plan is to run 2 co-ax (sat grade) from the loft to a distribution point, then 2 cables to 3 different points in the house.
Got a little confused as there is just a rubbish complicated note explaining what is meant to be installed giving acronyms and part numbers (!) , could just do with a simple diagram for a simple spark. Customer believes a CAT5e needs to go in, I don't know what for if it is for the TV or something different. HELP!
I use an HDMI over CAT5e box it comes from an HDMI splitter out of my sky box then runs up the CAT5 and into the reciever box in our bedroom so we can watch HD upstairs. We change the channel via the coax and magic eye still and still get the sky over coax if we want or HDMI.
I'm sure all of the above is of no use to you, but a simular setup might have been discussed with the customer?
Reply to Cable help in the FreeSat, Sky, VirginMedia Forum area at ElectriciansForums.net
Hi all, Merry Christmas to everyone, and apologies for talking work during the holidays😅 I have my first EV charger install job early in the New...
My wife has a electric heated airer, our dog chewed through the cable and I thought it would be no different from rewiring a plug. It's not. I...
htps://we.tl/t-JHXw09romZ quick share to photo Hi there. I am trying to convert previous cable network cat5e installed when had non fibre in 2015...
hi guys / girls , any advice would be appreciated, So the situation is a domestic property has a 3 phase supply , from the service head we have 3...
Hi all I’m after a bit of advice regarding wifi/secondary router. Data is not a strong point of mine so any advice would be very much...
