T
TenetJohn
Ok all,
I'm looking at a shower install and need a bit of advice selecting the correct cable for the job.
The customer has a 10.5 KW shower. There are no cable factors to apply, all clipped direct in the loft from the consumer unit, above insulation, to the bathroom.
I was going to use 10mm T&E however the customer already has 25mm X 16mm mini trunking affixed from the ceiling, down to the shower.
It's not possible to top entry, only bottom entry is available, so the trunking runs down the side of the shower, with a 90 degree flat bend, bringing the route across the bottom.
The customer has refused for any damage to the wall tiles, it's a concrete wall too so can't drop through studs for rear entry.
I'm concerned that I can't meet the bend radius for t&e as it's a very sharp 90.
Has anyone and recommendations on a suitable flex that would fit the existing mini trunking?
Tenet
Tenet
