Discuss Can you charge a 24V battery with a 54.6V charger? in the UK Electrical Forum area at ElectriciansForums.net
maybe work with 2 x 24V batteries in series. always assuming that the charger is suitable for the type of batteries.
It may not be compatible with the batteries either (ie NiCd, Lion etc.) as per #4, which could cause damage to both!
Reply to Can you charge a 24V battery with a 54.6V charger? in the UK Electrical Forum area at ElectriciansForums.net
I will be putting together 2 x 12v lead acid battery connected in series (24v basically) backup power for Internet connectivity (routers/wifi etc)...
I will describe my problem in as much detail so you guys might be able to answer my question. I am never home, my Electric bill is $ 28 to $30 a...
I place the battery on the charger and it is green for about 10 seconds, then flashes red. I placed the same battery on my kobalt 18-20v...
hello guys i have a (3-6v dc motor), (DC Motor PWM Speed Controller 3V 6V 12V 24V 35V), (3.7v 1200mah rechargeable battery) and a (Charging /...
Good afternoon, I have a 2 year old car battery (AGM 760 CCA) in a 2022 Hyundai that constantly "seems" to lose its charge. I'll check the...
