Discuss Cold weather and rewires in the UK Electrical Forum area at ElectriciansForums.net
How do you guys go about installing cable around the 5 degree range, when the cable is a total pain to work with?
don't think the customer would be too pleased if you phone em to say you can't complete their rewire as its too cold!!A ''Rewire'' at 5C?? I can understand a new build or an open complete refurb job, but most rewires would be in surroundings a bit warmer than 5C, i'm sure!!
Shouldn't really be working with PVC cables at or near 0C temperatures and below...
Take the wife to work, and get her to breathe on the cable
yeah bring a heater if your sat on your backside all day, but in most cases doing a rewire usually generates enough body heat alone!! lol!!Well you could always hook up a temp supply to the central heating system, or bring a couple of electrical blower heaters you could hook up... lol!!
I don't set the minimum temperature recommendations, that comes from the cable manufactures, that according to the wonderful BS7671 you should be following...
don't forget to bridge out the overload on the tranny first. :ack2:Link L&N at one end of the reel, then connect the other ends to L and E on your 110V Transformer for a while.
That should loosen it up for a bit, plus it'll warm your hands whilst you're pulling it around.
Reply to Cold weather and rewires in the UK Electrical Forum area at ElectriciansForums.net
