Discuss College assignment need help please in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
C
c4m3ron
Hi Im currently doing my nvq level 3 and im stuck on a question.
4a Select using manufacturers date, suitable equipment foriated equipment for the solar photvoltaic arrays and associated equioment to be located on and with the property?
4b show on drawings / overlays / copies suitable postions of the equipment selected
Any ideas guys im completely stuck. Thanks
In other words, you haven't got a clue either!!!!
well the wording is a bit obtuse, but I reckon I can just about manage to select the appropriate equipment for an installation, and scribble a diagram on the back of a napkin or something.
serious answer then... use mastic to stick the panels to the roof, blutack the inverter to the wall, and run the cable down inside a drainpipe so it can't be seen, then connect in to a shared ring circuit to save messing around under the floor boards and consumer unit, stick a meter in somewhere, maybe at the base of the drainpipe, and make sure to hide all the broken tiles under the pv array so the customer doesn't realise about them until next time it rains - if it's already raining then be sure to make a sharp exit having made sure the customer hands over the money due in cash to avoid paying vat.
Pretty sure that's how half the PV trainers out there think it should be done anyway so you should get a pass with that answer no problems.
This is scousespark that got chucked off last night for terrible language and rudeness, exactly the same post, next he'll ask why functional testing is necessary
Reply to College assignment need help please in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Hi I'm currently doing C&G 2365 Level 3 I'm working through the 305 design assignment (Swimming pool, hotel etc.) Other then this assignment I...
4K
Hi guys, I've gotten AI to write up a terms and conditions for my company and then went through it with AI and tweaked it to make it sound a...
I know how I was taught to test a RCD, 6 tests in all two no go, two under 300 mS and 2 under 40 mS with no load. But thinking about it not so...
Dear All, Newbie here, not sure if this forum is for those who specifically electricians only or if general people can join for help and advice...
8K
Hi, I'm new to the electrical field, have passed my level 2 and learning my level 3 but regrettably have very little 1st fix experience. As an...
7K
