Discuss Converting 240VAC to 12v DC in the UK Electrical Forum area at ElectriciansForums.net
What current do you need at 12V and what type of device is it powering? There are many different ways of doing this, some are more suited to certain applications than others. For example, that LED driver might not work well for a 1A motor load because of the starting current. But a simple transformer-rectifier which would be fine for a motor, would be unsuitable for a piece of audio equipment due to voltage ripple.
So more info needed please...
You need a well regulated, smooth DC supply so no not one of those.How about LED inline drivers Lucian?
providing the output voltage is correct, would they be appropriate?
Definitely not! That's just an over priced diode in a case, or maybe four diodes if you're lucky.Thanks for the help Lucian.
How about inline converters like these
www.mr-resistor.co.uk/item.aspx?i=7579
If you look at the little diagram top right in your link you'll see that a transformer is required in the circuit, and then this appears to be the rectifier part. Using this on its own, powered from the mains, will destroy your routers!How about inline converters like these
I believe he is trying to avoid these.Those appear to be just rectifiers, that turn 12V AC into 12V DC, based on the statement: "This allows LEDs to be run off AC transformers." Why they would sell an electronic product with no specification (what current, voltage etc can it handle?) and no real description I am not sure. Anyway, no.
Ignore these lighting products, buy normal wall wart PSUs like the ones in my links. They are the types of product supplied new with the routers. Anything much smaller/cheaper/weirder probably isn't suitable.
Followed by a capacitor and a regulatorA transformer and a bridge rectifier is a good start
Reply to Converting 240VAC to 12v DC in the UK Electrical Forum area at ElectriciansForums.net
