- Reaction score
- 10
Hi, just started a brand new install, the building has 160a 3phase service head. Waiting for meter install but N power are requesting CT panel photos and also pictures of main switch. Last job I did from scratch had a 250a 3phase supply and Northern power supplied and fitted the CT panel which also housed the main fuses, this time they have just put a normal type of service head, am I going to have to fit another ct panel after the service head ? Im pretty sure metering has to be via CT over 100A ? Problem is I haven’t quoted for this ! Also do I need a separate switched isolator as only has 1 DB so surely main switch on that’s just main isolation Point ? Any advice appreciated !
