Discuss Earthing Faceplate in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Mark.W
Hey Guys,
I'm in a discussion with another spark about whether or not he earths the metal back box of a floor socket box. He seems to think there's no need because the faceplate gets self drilled to the back box and it doesn't have lugs like a standard metal Patress?! The faceplate screws aren't linked to the earth terminal in the socket either but he seems to think it's fine.
What's your guys thoughts?!
I know this has been discussed in the past about standard boxes but I couldn't find anything about floor boxes.
Cheers Mark
the box should be earthed. however this is done depends. if it's not earthed by the faceplate screws, then a fly lead should be fitted.
The Earth terminal is there for a reason, so IMO you should use it, if anyone gets a belt and the investigation, should there be one finds the terminal has not been earthed, whoever did the install will be in deep dodos
Without being able to see the set up one thing worries me, if you are relying on tne faceplate to provide earth continuity to the back box, what happens when you remove the faceplate and the box and associated trunking or conduits become live? if you get my drift.
These floor boxes are most likely fixed to the sub structure of the building fabric by various routes, the should be connected to Earth common sense dictates that they should be connected to the general mass of Earth regardless of some Muppet questioning it.
Reply to Earthing Faceplate in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hello everyone, Following on from my previous post where I received advice on taking a spur off a 40a feed (thank you). I performed the work...
I have just checked a double outlet and it trips at 18ma. It was supposed to be faulty. Washing machine had a bad heater which got replaced but...
Hi, I've bought a "yagusmart" smart switch from Amazon and it has no earth terminal. Although there are no metal facing parts I would think the...
Hi, This post is about my concerns with medical IT socket outlets and want to alert you all if you are fitting them in a hospital. The current...
2nd fixing some sockets in an office today and we were talking about high integrity earthing, I've not got a clue what the sockets are going to...
