- Reaction score
- 0
Hi,
I’ve just moved into a new flat with an Electrastream boiler, and when I first moved in it seemed to get to around 45 degrees in around 45 minutes. Now, (about two weeks later) I’m luck if it gets to 40 degrees in an hour. This seemed to happen after a new shower was fitted.
Can anyone suggest a reason for the increased length of time it takes to heat up? (The manufacture says it should take 50 minutes to get 50 degrees). With the boiler rated at 9kW, I’m keen to minimise the amount of time it takes to reach optimal temperature - anything less than 40 degrees is too cold to shower.
