E
edrobbo8
Hi all,
My sister runs a rally driving school which has a workshop where they prepare and repair the cars, and as such have 3 ramps which are operated with 3 phase hydraulic motors. They also have a MiG and TiG welder, both single phase less than 16A supplies. They have a 3ph compressor, and various other bits of single phase kit such as grinders etc.
They moved to this new site a couple of years ago, and before they moved the gyppos ransacked the 11kV substation on the site and nicked all the copper from the tranny and all the cables. So now they are still trying to get a new 3ph supply in, and at their old unit which was a new build commercial unit they had a 50kVA, 100A 3ph supply.
I am sure in my head that that is the size of supply they need for the new unit, but the electric company have just sent this through:
[TABLE="width: 565"]
[TR]
[TD]Type of load
[/TD]
[TD]kVA
[/TD]
[TD]Additional information
[/TD]
[TD]kVA
[/TD]
[/TR]
[TR]
[TD]Lighting
[/TD]
[TD]
[/TD]
[TD]
[/TD]
[TD]
[/TD]
[/TR]
[TR]
[TD]Space Heating
[/TD]
[TD]Restricted
[/TD]
[TD]
[/TD]
[TD]Unrestricted
[/TD]
[/TR]
[TR]
[TD]Water Heating
[/TD]
[TD]Restricted
[/TD]
[TD]
[/TD]
[TD]Unrestricted
[/TD]
[/TR]
[TR]
[TD]Air Conditioning
Plant
[/TD]
[TD]
[/TD]
[TD]
[/TD]
[TD]
[/TD]
[/TR]
[TR]
[TD]Catering Equipment
[/TD]
[TD]
[/TD]
[TD]
[/TD]
[TD]
[/TD]
[/TR]
[TR]
[TD]General Power
[/TD]
[TD]
[/TD]
[TD]
[/TD]
[TD]
[/TD]
[/TR]
[TR]
[TD]Other Equipment
(please specify)
[/TD]
[TD]
[/TD]
[TD]
[/TD]
[TD]
[/TD]
[/TR]
[TR]
[TD]Total Capacity required
[/TD]
[TD]
[/TD]
[TD]
[/TD]
[TD]
[/TD]
[/TR]
[/TABLE]
If any welding equipment is to be installed, please provide details of this apparatus, i.e. the 'Maximum Welding Power', whether 'point-on-wave' switching is employed, the frequency of current fluctuations and whether 3 phase or single phase.
Please provide the following motor information.
Is it worth working out for every item they use or can you just say in Layman's terms that they will need a maximum of 50kVA or similar supply?
The power company will be taking the supply from the other side of the main road where there are converted farm barns which are used for a variety of commercial uses.
I would be grateful for any help from anyone who deals with the power companies and how to explain in easy terms what is required!
Thanks for any help.
[TR]
[TD]Type of load
[/TD]
[TD]kVA
[/TD]
[/TD]
[TD]kVA
[/TD]
[/TR]
[TR]
[TD]Lighting
[/TD]
[TD]
[/TD]
[TD]
[/TD]
[TD]
[/TD]
[/TR]
[TR]
[TD]Space Heating
[/TD]
[TD]Restricted
[/TD]
[TD]
[/TD]
[TD]Unrestricted
[/TD]
[/TR]
[TR]
[TD]Water Heating
[/TD]
[TD]Restricted
[/TD]
[TD]
[/TD]
[TD]Unrestricted
[/TD]
[/TR]
[TR]
Plant
[/TD]
[TD]
[/TD]
[TD]
[/TD]
[TD]
[/TD]
[/TR]
[TR]
[/TD]
[TD]
[/TD]
[TD]
[/TD]
[TD]
[/TD]
[/TR]
[TR]
[TD]General Power
[/TD]
[TD]
[/TD]
[TD]
[/TD]
[TD]
[/TD]
[/TR]
[TR]
[TD]Other Equipment
(please specify)
[/TD]
[TD]
[/TD]
[TD]
[/TD]
[TD]
[/TD]
[/TR]
[TR]
[/TD]
[TD]
[/TD]
[TD]
[/TD]
[TD]
[/TD]
[/TR]
[/TABLE]
Size of largest three phase motor | kVA | Size of largest single phase motor | kVA |
Starting Current | amps | Starting current | amps |
Type of start e.g direct-on-line, star delta, other(please specify) | | | |
Frequency of start e.g. 5 times per hour | | | |
