Search for tools and product advice,
Discuss enlarge existing hole in metal panelling in the UK Electrical Forum area at ElectriciansForums.net
hey guys / girls,
Whats the best way to enlarge a round hole in overhead metal panelling ?
Unfortunately i cant find a holesaw the correct size , so advice needed.
thanks
at that size, what's wrong with a jigsaw for a one-off?
yes , but still be interested to know how to sort it if 1 wasn't available for future reference
At the end of the day there aren't that many ways of making a circular cut in a panel of metal. A hole saw or punch is where my mind starts. A jig saw is probably the next most practical. A gas axe is probably over the top! An angle grinder and lots of filing is possible but will be messy. Using smaller hole saws many times and some filing is also possible.
I'm not sure there's a right answer to your question or that I'm helping much!
thanks for the response , tried looking for a fine toothed narrow blade for multitool , but cant seem to find anything suitable.
There are metal blades for multi-tools and I missed that off the list. In my opinion it would be quite hard to multitool a large circle as the material will be vibrating like mad and you'd have no easy way to counter this.
On a serious note, depending on how thick the material is that you need to cut, maybe a Dremel could work?
Of course, I notice that no-one has yet suggested doing it the old way with a stitch drill.....
Decent quality holesaws are available in 160mm for much more reasonable prices, but you stand a good chance of pulling the gearbox out of a drill or breaking a wrist using them to cut sheet steel.
Nibbler by far the best option.
Good old fashioned adjustable tank cutter. These were used for cutting holes in steel water tanks, and mine probably dates back to the '50s, but they are still available new.
They need a well located pilot hole, so you'd have to 'fill' the original hole first. This could be a 100mm long piece of thin steel bar, pop riveted across each hole in turn.
Pretty much the same as the tank cutter that Brian was on about.
They're a great tool as long as you make sure the outer blades are lined up and everything is tight. I have a strong feeling the guard isn't stopping the dust, it stops the bits flying out and hitting you because they are loose.
Grey tool for cutting through Mdf/ply for the pan connector to pass through for built in toilets!
Reply to enlarge existing hole in metal panelling in the UK Electrical Forum area at ElectriciansForums.net
Metal building with living quarters the panel is on the outside and about 20 feet away from new build that will be 2x6 what type of shielded wire...
Hi all. I am installing some metal trunking vertically in a meter cupboard to contain all the meter tails for an apartment block. I have 5 sets...
I recently purchased a rural property in Arizona. The property receives power from APS, the local electric utility. Power arrives from the...
I'm homeowner and moved into a property which has 25 halogen downlights, I'm hoping to get an electrician to replace these with LED ones, what...
