Discuss Eversolar TL4000 - G83 or G59? in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
whinmoor
We planned to install 20 x 200W panels using an Eversolar TL4000 in Norfolk. We applied for G59 permission but the DNO (EDF Energy Networks) hasn't yet responded to us. Can this inverter be installed under G83 as most of the documentation supplied with it refers to G83? Or can we remove one or two panels and continue with the installation? Installation date is Thursday so we need to make a decision. Would you just go ahead and install it assuming permission would be granted?
Thanks for any advice.
just done it under G83 u wont have no probs!! they up to armpits in it by now bet they just tic tic tic at mo!!!!!!!!!!!!!!!!!cert it states G83 compliant !if u want to be 100% then yes remove a couple but im sure it wont be a prob!!!!!!!!!!!!!!!!!
I'll be honest - I haven't received a reply from the DNO for three installations which I plan on using SB4000TL inverters. We're going to install anyway. What choice do I have?
Reply to Eversolar TL4000 - G83 or G59? in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Hi all I had my PV/Battery setup installed in May and since then all my excess PV is just fed back to the grid for free. When I initially tried...
I have a partially completed installation of solar PV. The panels and inverters are working fine and generating plenty of power (13kWp), but I am...
So, I already have solar (an older FITS installation) and it's been particularly successful so I want to extend this. I'd like to do two things at...
Good evening all - I used to be a member of this forum ages ago, but couldn't work out what my username and old email address was, so decided it...
4K
Hey all, Thanks for any advice you might be able to offer. I thought I posted this earlier but apparently not, apologies if it is a duplicate...
