Discuss fault finding on ring splitting technique in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
S
schoe
Hi all can anyone explain how to carry out fault finding on a ring main using the splitting the ring technique.
Other than splitting a socket and testing each way do you have to do anything in the consumer unit, ie do you leave the wires in the circuit breakers and bus bars or do you split them as well?
Thanks very much chris
Split the circuit at the DB, and also at what you think is the mid point socket! Joint between conductors you need, and test away. Just think of it as 2 radials! Then once youve narrowed it down to which side of the ring, split it again and work from there!
Reply to fault finding on ring splitting technique in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Hi, while carrying out an EICR at a farm cottage on Friday i came up against a problem early on. Whilst measuring the Ze the reading i obtained...
Hi all I don't appear to be able to post in the DIY forum so apologies if this is the wrong place. I live in a block of flats with an external...
Hey there, Sorry I’ve just joined up. I’m a qualified electrician/Electrical engineer. Recently sat my 2391-52. My question is I had a fault...
Hi all , after some opinions on N-E fault or ring main. After chasing this fault and ruining my bank holiday weekend , ring main IR readings as...
