Discuss Fault in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
T
Thewiz
Hello... Got a call from a. Customer saying when ever they plug in there 2kw heater it trips...
So One shal think the heater is faulty. I told them to unplug it and turn the rcd back on.
they rcd then restet... I thought over load may be a issue but she said she unplugged everything. She then plugged all the other items back in and it was fine.
But it she then got another heater and plunged that in put it in leval 2 and pop trips again.
Not been there yet.
Any by thing I should be looking out for when I arrive this week. Not seen this before ever. May be the fault current is to high? Maybe a slight short not big enough to trip the rcd but once the heater is on takes it over 30ma???
Not been there yet.
What happens when they use something else at this socket?
Maybe take a new SO with with you.
Not been there yet.
Do you mean accumulative earth leakage?
Don't ever, ever even think about being disrespectful to 8 Ace!
He is a role model for generations of Geordie youth!
You're getting close to me declaring pagga on ye bonny lad
(Pagga= the geordie version of a fatwa)
Reply to Fault in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi, I seem to have an RCD that keeps cutting the power at random times without actually tripping, if I reset it, the power comes on and will stay...
I have just checked a double outlet and it trips at 18ma. It was supposed to be faulty. Washing machine had a bad heater which got replaced but...
Called out to fault on RCD tripping maybe twice in a month for sometime. Did all the tests & found RCD was faulty, Refitted a new Rcd Type A which...
I'm writing this mainly hoping something occurs to me while writing it! I got called to an occasionally tripping RCD. It's a Hager double height...
Hi Guys, I'm having trouble diagnosing a fault on a customers downstairs socket ring, which only ever trips when the washing machine is used. The...
