Discuss Faulty gas meter? in the UK Electrical Forum area at ElectriciansForums.net
Also how did you check for gas leaks? I know a couple of ways of doing this. One has fallen out of favour these days as it is considered to be a tad dangerous, and the other should only be carried out by a Gassafe chappy.
So the gas meter dials spin when the boiler is on and stop spinning when the boiler is off?
Do the dials on the electric meter spin if you switch a big load on and then stop spinning when you switch it off? I think you'd better check just in case there is electricity leaking all over the floor, it'll stain the carpets something rotten y'know!
Yes, no and the customer has a clever vacuum cleaner to tidy up the mess!
Exactly what I was thinking.
Paul, why were you checking gas meter dials pre and post working on the electrical installation?
gas meter is in the same cupboard and noise of dials spinning is very audible, didn't check pre work per se just didn't hear them going beforehand
Most gas meters make a fair amount of noise when a high demand is made like a boiler starting up from cold.
Reply to Faulty gas meter? in the UK Electrical Forum area at ElectriciansForums.net
