Discuss faulty meter? in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
P
powervan
Been to job today (not my install) 3.6kw installed november produced 48units? inverta no display!! never got there remote display! company OUT OF SOLAR NOW?? tested array ALL GOOD! so can only be meter what about changing meter ? anyone done it (esp if not your install? what do u think it should of produced south facing 30deg pitch no shading?
I would agreee that it should have done more than 48 units but I dont know the procedure for changing it, maybe there isnt one....however only other thing I can think of which you prehaps overlooked is that whats the inverter is like ? if it dosent have a display is it a cheap crappy one ? does the spec of the inverter complement the specs of the panels ? something to think about.
Is the meter wired the right way round. Whats the output of the inverter, amps and volts. Is the array or part of it shaded? is the cable sizing correct for the length of the run or is the voltage drop outside limits? Is the meter a well known make?
I guess a meter is only 30 quid so is a cheap component to change.
According to the Guide to the Installation of PV Systems 3rd Edition it says <3% between the array and the inverter at STC.
Reply to faulty meter? in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Hello Our 4kW solar system generated 4.4kWh today (Sunday 13/03/23) compared with our neighbour’s 6.4kW system which generated 19kWh. Clearly...
I'm in a questions asking mood tonight. I briefely looked at a job today and I need to recommend a board change but need to justify it. Firstly...
Hi, Similar'ish question to my other thread but little more info now so a different approach but sorry if duplication. UK, single phase. Just had...
I'm hoping someone out there has come across this problem. Just had -8 days ago- a 6k solar panel system plus 4.8k battery pack installed. When...
9K
