Discuss Feeding bathroom pump from an immersion heater? in the UK Electrical Forum area at ElectriciansForums.net
Hi, I'm looking to add a bathroom pump. I'm wondering where I can get the power from? The spur pictured is feeding an immersion heater. The pump to be fitted currently has a socket but unfortunately its under 3m from the bath. Bit stuck so any advice would be greatly appreciated. Thanks.
no problem feding from redundant FCU as long as it's fused down to suit the cable to the pump. circuit to be tested and a MWC produced.
I have all old MK in my flat, and they are from the 70s. The double sockets have four screws towards the middle, but there's only 3 in the whole house, the rest are singles. The original switches are just fine, and while I thought of modernising them I just can't bring myself to update them...
Reply to Feeding bathroom pump from an immersion heater? in the UK Electrical Forum area at ElectriciansForums.net
Hi, I know it's best practice to run an immersion on a dedicated circuit but am I OK with the following A new heat pump is being fitted and it...
Hi, Small flat, currently has a small'ish feed water tank, top of a cupboard, feed through a wall into under stairs cupboard. Hot water tank...
Hi all, Got an awkward bathroom fan installation in a downstairs flat, concrete ceilings and (some) walls. Bathroom is already fully tiled and...
Good morning all, I am currently working on a House in Multiple Occupation (HMO) consisting of 10 flats, with three parking spots equipped with...
DIY and new to the forum Hi there. I want to install a simple bathroom heater in my bathroom (this one: Wall fan Heater 7 DAY Timer PTC bathroom...
4K
