Discuss Fire alarms installation and testing in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
eol devices are used so that the panel "sees" them in non-fault conditions. if it doesn't see the device, it goes into fault ( e.g.open circuit cable ). if it sees a resistance of , say, < 1K Ω, it goes into fire
All will depend on what make of panel you are using....The basic method of fire alarm panels, is to monitor the cable as well as detecting a fire condition. Making a system, able to report a fault on the cable or device. The control panel has a comparator circuit, which basically measures the voltage, in relation to the resistance (ohms law, as Tels post) so in normal operation 6k8 ohms/24v = ok.. 470 ohms/8v = fire.. 0 ohms/27v = o/c fault....>6k8 ohms/<2v = n/c fault. Hopefully diagram will help
What does the first switch in that diagram represent?
Unless I'm being daft it looks like it puts a 470r in series with a 6k8 which would raise the potential the comparator above 24V and show an open circuit fault wouldn't it?
Sorry I have made a mistake in this diagram the 470 ohm resister should be switched against the blue negative line as others are show......Thanks for spotting that Dave....updated
fine if the eol is a pure resistor. some are more complex and as such can't be read on a multimeter. hoewver it's easy to operate a call-point and get the expected 470Ω .
Early SWL systems on cranes (pre pre CanBus) had similar arrangement for assessing conditions,three interlocks,or limit switches with varying resistor values,basic control board determined what was happening by reading resistances or combination of,O/C or full continuity reading as a separate fault. Cannot say i miss monkey clambering up a 300' strut jib with a gas soldering iron and a bag of assorted resistors...:willy_nilly:
The resistor is the most common method, using 470 call points, but as you stated Tel ...Active eol units are on the market, but less common now as most have been taken off the market with new EN ruling.
They were very simple but a clever idea, using binary code depending on the order of 4 switches. you could control 15 separate operations down 4 cables.....this is now the basic principle of cambus and addressable alarm systems using 8 switches to select the binary code, but now it can be sent on a 2 wire power line, with over 250 separate operations.
Reply to Fire alarms installation and testing in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Daughter has bought a house and it has a home security system, G-Tag setup. Issue is the alarm panel displays are pixelated and you cant see...
Hi, I have a veritas R8 alarm and corresponding keypad. Recently a powercut caused one of my keypads to stop working. I replaced the battery in...
Hi all, i'm just after a definitive answer regarding a fire alarm system in a communal area/stairwell. There are call points, smoke heads &...
I'm installing mag-locks and fire door hold-open magnets at the moment and I'm wondering if any of the cable should be fire performance cable...
I'm about to order this wired smoke alarm system as it can network but I just went to see how my existing fire alarms are hooked up and there...
