Discuss fluke 1652 tester in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
soulman
hi, im just practicing a bit of testing for next year at college. i have a fluke 1652b and managed all the dead tests. however i have no instructions and having a few problems trying to perform live tests. Can anyone explain how to perform a ze and pscc and pefc.
cheers
if i rember correctly (while since i had a fluke) the fluke uses 3 leads and carries out both tests at once, cycle through the buttons till pfc appears below the main display then carry out ze test and pfc will show in smaller writing underneath.
cheers
Go to the fluke website and download the free instruction manual.;)
Cheers.........Howard
hi thanks for replies figured out how to do tests. i think do these results sound about right. tncs system test rig connected including consumer unit connected via plug.
ze: 0.63
pefc: 397A (0.397 KA)
pfc: (643A (0.643KA)
Also can someone explain what RE is for when you push f3. you can toggle between this and pefc
cheers:)
Reply to fluke 1652 tester in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Am absolutely gutted, my Fluke 1587 insulation tester appears it's had an unknown fatal incident. I was doing some testing a few days ago and was...
Hi All New to this forum, have read the posts on here from google but only recently signed up. I'm having some issues and some input would be...
Hi all, We have a limited in house PAT testing requirement and were advised that the TIS700 fitted our needs. The unit works fine for 110V and...
I had Scottish Power moving a supply this morning from one building to another so an extension could be built. I had everything ready for them...
