Discuss Fluke tester doesn’t work odd?? in the Electrical Tools and Products area at ElectriciansForums.net
I’ve recently come into a people’s with my fluke T130 I’ve been proving it recently on my fluke proving unit and it shows 60v then ramps up to 90v and cuts out I then put it back on and it ramps up to 160v then cuts out I then do it again and it goes to 261v and cuts out! I’ve tested my proving unit on various testers and it seems fine with everything else! What could this be??
I'd say put new batteries in, and if that doesn't cure it then it's knackered.
I take it you've tried it on live mains?
Yeah I’ve tried it on main and it tests fine like I turn switch off and it goes on and off etc just doesn’t show 240v on the probing unit which my other testers do? Really odd
How old is it? Fluke did a recall on a batch of T110, T130 & T150. I had my T110 replaced earlier this year. Take a look at the following link.
LINK!!
It’s pretty old the button is missing on the front so not sure it would be replaced as a recal? I got given it by my old overseer whilst doing my apprenticeship so. It bothered as I have a multimeter, clamp meter and voltage tester (T150) all fluke just wanted to get it working as a spare?
Try flexing the cable on both the probes too.
First sign of any random behaviour and a 2-pole goes in the bin - it's too important to take chances with!
I’ve tried that and it’s fine the odd thing is it will test any voltage accurately bar the proving unit! It doesn’t seem to like it! I feel as though I should get rid of it but I’m just curious as to why it wouldn’t like the proving unit !?
Mine wasn't working at all, still got a brand new one from the recall. Check the serial number. If it's in the recall it'll be replaxed
Worth mentioning that Fluke also have a recall on their old socket testers (and Robin branded testers) in case anyone has one lying around. Not new for old, but option of 2 pole tester or something else in exchange.
LINK!!
THANK YOU. I had no idea about that - my (10 year old!!) T110 is now also in their system for replacement.
Reply to Fluke tester doesn’t work odd?? in the Electrical Tools and Products area at ElectriciansForums.net
Hi All New to this forum, have read the posts on here from google but only recently signed up. I'm having some issues and some input would be...
I had Scottish Power moving a supply this morning from one building to another so an extension could be built. I had everything ready for them...
Good evening, I have recently moved into a new home and I am having problems with the MCB/RCD tripping (Mem M6 Type 3 - 30mA). It intermittently...
Evening all. Been at a property the last couple of days that had suffered damage due to a surge. I got the power back on all circuits apart from...
Hello everyone, I’m based in the ROI and live in a rural location. Yesterday evening my electricity supply started to switch on and off randomly...
