Discuss fused spur off an unfused spur in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
sivoodoo
Hi all,
Is it permited to add a fused spur feeding an outside light from an unfused spur from a ring.
I know its ok to have one unfused spur from a ring.
The setup is as follows:
RING ----- Unfused spur --------- FCU -------- Outside light.
Regards
Simon.
depends on cable sizes and circuit protection
look in the appendix of the regs, figs 15A & 15B
If you have one of the first copies of the 17th it contains errors, but you can get the corrigendum(big word) with the altered pages from....free download
IEE Wiring Regulations updates - The IET
usefull site this for downloads, if you need free downloadable test certs for example use this link
Forms for electrical contractors - The IET
little tip, when you click on the link and the redirecting page appears , click on the link on that page it will take you straight to it.
otherwise you end up on the IET site and have to search
Reply to fused spur off an unfused spur in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Grateful if someone could offer some advise, I'm struggling to find a definitive answer to this. I have a double socket, it was on the ring main...
Hi guys, newbie posting! Does the following sound ok... Existing circuit: SOCKET on a ring -> spur to SWITCHED 3A FCU -> SWITCH -> hardwired FAN...
Hi all, My mother wants a double socket adding next to a desk, behind the desk there is a 10mm (i dont know the MCB in the Consumer Unit) which...
Evening all, I’m looking to install an outside light as a spur from a socket on a ring main. There is already a spur from this socket supplying...
Hi, if getting back to the CU is not an option, instead of spurring off a socket via a Sfs putting the rating down to 13a. Could you spur off the...
