Discuss grey area in the Industrial Electricians' Talk area at ElectriciansForums.net
N
nelson19
Hello all would like your personal opinions on this,
at what point does the extent of electrical additions or alterations require the installation of kitchen and bathroom fans, and smoke and heat alarms if not already present?
or would you only install these in a full rewire or new installation?
thanks
The electrical instalation extent, whether small or large has little or no bearing on either the fan or smokes
The smokes are a recomendation for installation,unless new build or extension when they need to be installed to comply with the building regs
Ditto the fans,the electrical stallation has no bearing on whether a fan is required,building regs stipulate when or if they are req
Reply to grey area in the Industrial Electricians' Talk area at ElectriciansForums.net
Hi all, i'm just after a definitive answer regarding a fire alarm system in a communal area/stairwell. There are call points, smoke heads &...
I've asked a similar question before I think and we came to the conclusion that apart from new houses and HMO's etc there aren't any rules about...
Hi all, I am looking for some advice regarding old rewireable (3036) fuse boards in regards to additions and alterations. I am an electrician and...
4K
I currently have a home with 7 interconnected, hard-wired smoke detectors. I have a hard-wired heat alarm in the garage that I need to have...
