Discuss Heating in the UK Electrical Forum area at ElectriciansForums.net
i=p/u
Evening.
anyone tell me a little about adding underfloor heating to a gas heating system..
at at present have 1 Chanel time clock to power gas combi burner.
what way the plumber do this ?
All the builder is saying is there will be manifold in corner.
Anyone tell me a little about it? Thx
yep.the tingy jobbie makes the whatsit work and them pipes warm the water, thus making one's toes hot while the body freezes
Typically you will have 2x two port valves, a pump at the manifold position and 2x programable room thermostats one for the UFH and the other for the rads.
As you can see from Lees drawing, there is a pump and diverter valve on the manifold.......unlike a normal radiator system, were hot water is pump around the whole system. The manifold pump, keep circulating around the under floor piping until it cools to a preset temperature. Only then is it diverted back to the boiler, so no hot water is ever returned to the boiler making it more efficient .
also makes sure the manifold is plumbed from the Flow and Return before the radiator circuit, otherwise the Rads will be on when the UFH is on, sounds obvious but I see it all the time.
Reply to Heating in the UK Electrical Forum area at ElectriciansForums.net
Hi Guys Changing my heating/water programmer and im stuck on the wiring ive gone from a danfoss to a Drayton and the wiring description is...
What’s the best setup for a system that has a heating system with existing radiators but a wet underfloor heating system is being added to a new...
Up until now I have steered clear of heating systems. I now have quite a bit of work with a builder and will be expected to deal with the...
I'm in the middle of preparing a quote for installing 12 x 3Kw and 4 x 2Kw halogen heaters in a church. The system design was provided by a...
Hi guys We are due to undertake a new build install where they are using air source. Its the first air source I have installed so need a bit of...
