Is there a way to know the colour temperature and RI of a light? without knowing the manufacturer's spec.
Hi Carolina,
Hope you are well.
I have tried to put together some useful information about Led Lights and how to know colour temperature and RI of a light.
About colour temperature
Colour temperature level, also called "associated colour temperature" (CCT), defines the appearance or color of a particular light. Most light bulbs send out a white light, yet this white light can range from warm to cool. Think of colour temperature level like you consider paint, where there are seemingly endless tones of white to select from. In the same blood vessel, there are a number of various colour temperatures for you to choose from when you're choosing new light bulbs.
Some lights, like incandescent bulbs, release a warmer light, while various other bulbs like LEDs give a larger range of colour temperatures to pick from. Many individuals like the heat of an incandescent light bulb, yet don't realize that this sort of light can be conveniently reproduced by merely choosing the ideal energy-efficient light bulb. If you're taking into consideration updating to LEDs or other power reliable bulbs, the light bulb colour temperature chart below can assist you discover the appropriate colour temperature level for your area. Yet before we start, allow's have a look at how to measure colour temperature level.
Exactly How to find out Colour Temperature Level
Correlated colour temperature level (CCT) is determined in levels Kelvin on a scale from 1,000 to 10,000. Unlike measuring temperature level in levels celsius, the warmer a light bulb's light is, the reduced its temperature will certainly be. A cooler temperature level will have a higher value.
For reference, candlelight has a colour temperature of about 2,000 K, while sunlight has a temperature level of concerning 6,000 K.
Why Does Colour Temperature Level Issue?
Whether you're searching for LEDs, CFLs, halogens, or incandescent light bulbs, there are a vast selection of power levels as well as colour temperature levels to choose from.
When we rely upon incandescent bulbs for all of our lights, we rarely needed to take into consideration colour temperature level when replacing bulbs in our houses. Today's energy efficient bulbs are readily available in a wide array of colour temperatures, and also lots of families who have started switching over to LEDs as well as CFLs experience frustration with their chosen light bulb since it emits a various light than what they're accustomed to. The light bulb colour temperature graph over can assist you determine the correlated colour temperature level (CCT) of your existing bulbs as well as find the excellent substitute for your room.
I hope that was helpful, if still have some questions please let me know so I can be more specific..
Best wishes
Aaron
