Discuss Help needed wiring led security garden light to outside. in the DIY Electrical Advice area at ElectriciansForums.net
CAN'T SEE IMAGES. THE SITE TAKES FOREVER TO LOAD. CAN'T YOU ATTACH TO POST?
can't make any sense without physically being on site to check and test.
if you are more to the west of manchester i could call and sort it.
Theres no lintel. "Builder said didnt need one cos its an extension" cowboy and ran off. Told him sort the garden light couldnt do that
It might be worth getting that checked out as it looks like the timber doorframe will be the only thing supporting the roof structure or whatever is above the door opening at that point.
  • Agree
Reactions: 123
Yeh im going to find someone to look at it. Walls needs to be plastered outside to. Do you think I can report the builder cos it looks dangerous to me. When he done an extension through kitchen to make bathroom he didnt even get wiring done directly from consumer unit. He used the security light wiring for the bathroom.
The two wires are loop in and out and they look like 2.5mm so potentially part of a ring main so you'll need weather proof 13A FCU but to be honest the whole set up looks sketchy so I'd recommend getting an approved electrician to have a look.
Classic Fawlty Towers...I envy you being so young you don't get it!
Plenty on here will...
go to about 29mins in...
all well and good, but in the scheme of things, we are just specks of organic dust infesting a lump of dust circling a hot bit of crap, orbiting a bigger lump of crap, destined to eventually collapse into a black hole , lost forever in time.
Crikey another rough old job.
Reply to Help needed wiring led security garden light to outside. in the DIY Electrical Advice area at ElectriciansForums.net
I want to replace light switches in my living room. There's 2 x double switches. 1 Controls 2 separate lights in the living room. The other...
Hello, I’ve have some ten year old Collingwood SL020 RGB led garden spike lights which I’d like to keep using but wondering if I can use them with...
I am currently looking to add 12v led cob strip lights to my mother's kitchen but confused what I need. There are currently mains wires under the...
Hi, there are 3 bundles of wires coming from my ceiling and I've been told they have been tested with a multimeter and have all got a current but...
Hi, I’m new to the forum. Thanks for letting me join. Asking for some diy advicd… I’m trying to add a couple more security lights to the existing...
