Discuss Help with Battery meter (golf cart) in the UK Electrical Forum area at ElectriciansForums.net
So I got my battery meter for my golf cart through Amazon today. I see two flat tabs where I think will need to connect directly to the battery. My question is, is there a purpose for the two round nuts above them? It looks like they would serve a purpose but not sure what to make if it. TIA
Unscrew the nuts, pull the bracket off, drop the meter through the hole, put it back on to hold the meter in.
Reply to Help with Battery meter (golf cart) in the UK Electrical Forum area at ElectriciansForums.net
Hi! Some help would be appreciated! I've just moved into new house, wanting to check insulation resestance etc as getting some nuisance...
So I'm looking to connect my car's battery directly to a Pure Sine Wave 2000w power inverter So I can use it on job sites etc to power a microwave...
I bought a used golf cart a few days ago which had their batteries replaced last year. They hooked up an am/fm radio to it and it worked fine when...
Hi All, I'm moving into telecoms and looking for some help on disconnecting battery strings. I come from a domestic background so have not got...
