Discuss Horstmann Economy 7 not working in the DIY Electrical Advice area at ElectriciansForums.net
roblowe
Hello, my Horstmann E7 isn't working in my apartment. I can here the clock timer ticking and the boost timer is working but no hot water is being expelled. The indicator lights for boost or timed are not lit up. Does anyone have any advice on how to troubleshoot/fix? Please let me know if more information is needed! Thanks.
Hi Rob, did you get sorted ? If yes, would love to know what you did... Having same issue in my apt, boost working but timing function not heating the water. The clock seems to be working fine & advancing on, but just not heating the water overnight... Thanks!
Reply to Horstmann Economy 7 not working in the DIY Electrical Advice area at ElectriciansForums.net
Hi, My hot water hasn’t been working properly since beginning of Jan, only working when I press the boost mode for an hour. I had a new timer...
Yesterday moved my Mum into her new bungalow. The Hortsmann had been off for a few months I suspect. The boost worked, but nothing happened...
Hi, So I'm trying to understand what's going on with my off-peak electricity supply, as something's wrong with it and I'm trying to determine if...
Hello, Apologies if this type of question has been asked before. I have no gas in my house so rely on a water heater to heat the water tank. The...
Hi all, Yesterday I returned home to no hot water after a few days away. After a brief inspection it seems the fault lies with the Horstmann...
4K
