- Reaction score
- 0
I have an outdoor electrical subpanel with a nearby outlet. We've plugged an extension cord with a built-in GFCI into it , but the GFCI trips every time, with any device plugged in. When we plug the same GFCI/device into a different outlet near the house, it works fine.
From my understanding of GFCIs, this situation should be physically impossible. Since the GFCI just compares the current coming in and out, even if the outlet were delivering too low a voltage or something, the GFCI still shouldn't trip at one outlet but not the other.
Does anyone have any ideas for what could be causing this, or further troubleshooting steps I could take?
- We've replaced the GFCI/extension cord, devices, outlet, wiring between panel and outlet, and breaker. Problem still happens.
- Extension cord(s) and GFCI(s) are rated for 15-20 amps, weather-proof, and cold weather. It's 30°F (0°C) out.
- New outlet and wiring are 20-amp, weather resistant.
- We've tried multiple devices, ranging from 250W to 1500W. All work when plugged into the side of the house, but trip the same GFCI cord(s) when plugged into the other outlet.
- The outlet measures 120V, and gets an "ok" from an outlet tester.
