M
maxime.corbeau
Hi everyone,
Is it possible to get an estimate on how much electricity a solar panel is going to generate throughout a year if I have the following information:
-basic product description: dimensions (e.g. 55x25 inches) and power (e.g. 100W), which is how solar panels are advertised on Amazon for instance.
-basic climate data: average sunshine hours (e.g. let's say I live in London and I wikipedia data: /wiki/London#collapsibleTable0)
If not, what kind of data am I missing (based on what I already have)?
Thanks.
its not that simple, you will need to design a system
Try this website
w-w-w dot sunnydesignweb dot com/sdweb/SunnyDesign/Home
Thanks for the link, but isn't there a simpler way to proceed? Can't I get an estimate (with something like 10% margin) with a manual calculation based on some sensible assumptions?
think about what your asking
a standard 100w panel will generate a completely different output if you face it north in Scotland or you live in Morocco and faced it south.
the 100w panel would still be a 100w panel, but, the output would be completely different
I know, that is why I provided a link to Wikipedia showing climate data for London which gives us the average temperature and number of sunshine hours per month throughout the year. Wouldn't I be able to make the calculation with that?
it took me a lot of college to learn how to design solar installs and I still use software.
every roof and every system is different
You could try using this site
PV potential estimation utility
You will need to enter location (on the map), data source (Climate SAF is a little more accurate, classic is more conservative), estimated losses (which depend on system, but you could enter 0% for the theoretical max), azimuth (i.e. deviation from due south which the panel is facing - again enter 0 for the theoretical maximum under ideal siting condition), and angle of the panels (again 35 is a good angle to get a ball park figure if the exact angle is unknown)
Matthew
that is a good link, but as I said you have to use software to get a return estimate. there isn't a 10% rule
I'm assuming that the OP only needs a rough and ready (back of envelope) ball park estimate of generation, rather than the level of detail needed for an installation quotation (the fact that it is a 0.1kW system suggest that this is not a install intended for FIT returns, for example).
to calculate solar output of panels you need to total up number of panels x watt output of 1, then direction of array which will affect production, then as a ball park to calculate amount of solar irradiation use the SAP calculation for orentation, taking into account shading, and angle on roof, this will give a good idea of annual output. If you need the formula's let me know
How much electricity will my solar panels generate?
maxime.corbeau,
sparks0755,
