Discuss How to use Memera 2000 program planner in the UK Electrical Forum area at ElectriciansForums.net
tonysc
Hi Everyone,
Hope you are well.
I've just moved into a flat. It has got economy 7(duel electricity tariff) floor heating/boiler. The mains switch is Memera 2000 and it has got a program planner as attached. Do you guys know how to configure the program planner so it switches on only at off-peak hours?
Much Appreciated & Kind Regards
Tony
Nobody?
It seems the timer made for that CU is a MEM AT1P or AT2P
Unfortunately so far I haven't found any instructions for it on the web ☹️
The same question was asked here in 2014 with a rather unhelpful response/outcome:
It's listed in the Memera old catalogue on the web, but the AT2P looks different to yours, so perhaps it's an AT1P.
I guess as a last resort it's a question of pushing buttons and seeing if you can work it out 🤔
I recognise the pic as being very similar to one I had in use a few years back, that I'd also installed to control storage heaters in a property on a sub main. Storage heaters and timeswitch are now long gone.
From what I remember, it wasn't the easiest thing to program, but did respond to button pushing and a bit of logic.
Is this a rented property? If so, I see another problem if a conscientious EICR is ever carried out.
There's a big hole into the inside of that consumer unit
Reply to How to use Memera 2000 program planner in the UK Electrical Forum area at ElectriciansForums.net
Good day readers, if any,I am an old sparky, a very old sparky. I can remember old Faraday giving us lectures Wednesday evenings at evening...
I've a 3 phase storage heater currently wired to the main fuse box in an office I have. The heater has 2 supplies/isolators, 1 for charging at...
Good evening, I have recently moved into a new home and I am having problems with the MCB/RCD tripping (Mem M6 Type 3 - 30mA). It intermittently...
Hi all, Last month I moved into a flat that is on an economy 9 tariff and meter (it has wet heating). In this scenario, I have one consumer unit...
Hi, So I'm trying to understand what's going on with my off-peak electricity supply, as something's wrong with it and I'm trying to determine if...
