Discuss How to wire a programmable thermostat in the Central Heating Systems area at ElectriciansForums.net
A
aj_clee
Hi,
I am wanting to change my old thermostat to a new programmable one (haven't chosen yet) but the problem is I only have a red and a black wire coming out of the old thermostat and all the new ones seem to need at least 3 wires. I do have a switch underneath the thermostat that turns a fuse on and off if this means anything?
Can anyone advise me on which thermostat to go for or help me with what the wires mean?
not that I don't want to give you advice but it would probably be best to get a quified spark in. you have not give enough info to possibly begin to advise you. and with all due respect your electrical knowledge does not seem enough to do this correctly and safely
Reply to How to wire a programmable thermostat in the Central Heating Systems area at ElectriciansForums.net
At the moment it depends on the weather on how well the central heating works, the main problem is the Nest Gen 3 thermostat only measures the...
Hello, I'm trying to upgrade my mechanical thermostat to a wireless one but when I connect the wires it doesn't work. This is the old one: And...
I currently have a Myson thermostat that is no longer working. I have a Meross thermostat to replace it. I have attached photos of the current...
Hey everyone, hope you all had a good xmas. Got called around to change over an old style pin type thermostat to a hive one for a family member...
Hi all looking for some helpful advice I'm an Aussie so go easy on me, I have a good mechanical engineering head but first time plumbing and...
