Discuss I have wired my electric wall fire into the fcu next to it . I twised the stranded wires and secured them in the terminals . in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
If they are fine stranded cables then you should be using a bootlace ferrule.
You may disagree Tel, but on the industrial plant I work on it is a requirement to use bootlace ferrules to avoid the risk of faults caused by poor terminations.
where did i disagree. just seen it. slipof the sausage fingers, replaced with agree.
my fault. i pressed the wrong ---. back to OP what is this word, "scrauded"?
However, some accessories have (or had) terminals suitable for fine stranded cables, in which case ferrules are not essential. A few types of terminal such as the older MK wrap-around screw with captive washer, as found on their flex-outlet FCUs for many years, were designed especially for fine-stranded and could not be used with ferrules.
Reply to I have wired my electric wall fire into the fcu next to it . I twised the stranded wires and secured them in the terminals . in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
I removed my baseboard electrical heaters (1981 installed) due to finishing off the room. When I had a new AC ductwork installed they changed the...
A rose in my 1970s kitchen ceiling became loose (one fixing screw had been inserted right on the edge of the hole in the ceiling) and when I...
Hi I've been planning to fit an outdoor junction box at the front of my house to hide a large brickwork hole and properly house the wiring...
Hi, there are 3 bundles of wires coming from my ceiling and I've been told they have been tested with a multimeter and have all got a current but...
I have a Security Light on my patio and until recently it worked fine. It stopped working and I couldn't decide if it was the LED Floodlight or...
