Discuss In-line duct fan run continuously in the UK Electrical Forum area at ElectriciansForums.net
C
chronyx
Evening all, I have just had a change an in-line duct fan after a week as the circuit board seems to have failed.
I can only assume the motor is still fine. It is feasible that other types of fan may run all day (Frequently used toilet, etc) and don't seem to fail often.
It is set to run for 8 hours a day and as far as I was aware, continuous running is generally better for motors rather than constant stop/start.
I don't have the brand/model to hand unfortunately so, in general, is this suitable use for such a fan?
Thank you!
Motors generally have a duty rating stated on them. It should say something like 'continuous duty' on the info plate although sometimes they just state the IEC 'S-Code'.
You're welcome Chronyx.
If the info plate on the motor or fan doesn't have a duty rating (or an IEC S-Code) you'll need to refer to the set up instructions booklet or the manufacturers website. If you still draw a blank in those places you'll have to speak to the wholesaler where you purchased it from.
Good luck :)
It just occurred to me that the UK regs could have their own duty cycle codes that are different to the IEC in which case to be BS compliant they'd use them instead. I'm not well up on the UK regs so maybe one of the locals can clarify for you.
Reply to In-line duct fan run continuously in the UK Electrical Forum area at ElectriciansForums.net
Evening all, Currently 1st fixing new extension however the existing cooker hood duct which was on outside wall will now be part of new utility...
Hi All, Bit of a tricky number. I have recently installed lights / fans /toothbrush chargers and shaver sockets to a bathroom and En-suite. The...
So I had a ceiling repair done in my bathroom due to water damage. The neighbors toilet above me was leaking for who knows how long. Mold...
Hello I have an old timed extractor fan in the bathroom which has stopped working. It has 3 wires which are black, brown and grey. I believe that...
Hello all, I'm renovating my kitchen and had a question about running wire around ductwork. In attached pictures - I need to have a receptacle...
