- Reaction score
- 4
Someone is connected to the grid with single phase supply and they have a 4kW PV array directly connected. They want to increase their PV generation, and add another 4kW.
I keep reading that if you generate more than 4kW you need a "3 phase inverter to split the load".
But I can't find out whether you can only have a "3 phase inverter" connected to a 3 phase grid supply, or if the 3 phase inverter would somehow work with a single phase grid connection.
Can anyone answer this???
