Discuss Indoor distribution circuits in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Amp David
Mentor
Have been working in a small packaging company today along with another local spark, installing a couple of single phase distribution circuits. 99.99% of my work is domestic, so was really along with him to help and learn a bit more at the same time.
The questions I have is why do some guys install 3 core and others install 2 core SWA for the distribution circuit. My 'mentor' today was pulling in 2 cores and using the armour as the CPC, where as existing distribution circuits were do using 3 core with the 3rd core as the CPC.
Is it personal preference or is it a case of if the CSA of the SWA is of the correct size it can be used.
It's often a bit of both, ECA recommend using all armoured cables as a cpc without the need for a thermal withstand check, with the exception of 400mm 2-coreand 120mm 2-core.
The 120mm was 'within a few percent of the size required' and is recommended to be used due to the low likelyhood of the cable being run at full current carrying capacity.
Using a third core can help where high Zs is a problem.
cost as well? I know you said indoor but i would still have more faith in the long term integrity of a core rather than the armour for R2
Some designers/specifiers/architects etc etc, stipulate the use of an additional core for CPC regardless of armour size compliance.
Reply to Indoor distribution circuits in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
I'm doing a college design project and need to choose a suitable range of circuit protective devices for the whole contact. I've chosen and...
Hello all, I wonder if I can get some opinion on my deliberations on an old TPN installation with numerous 1P sub-boards wired up with 16mm T&E...
For context i am in my 2nd year in college and my head is going round in circles a question in my project for which i need to select the right...
4K
Firstly, please go easy as I'm still a trainee! Working on my L3 2365 I'm having trouble understanding the rationale behind adiabatics...
