Hi guys here is the situation,switching all 4 heaters in induction hob(7.4kW)and it stops working.Taking out the oven (2.5kW)which is just underneath and find out that hob and oven are both plugged in to double socket.There is no cooker connection unit but there is cooker switch above.From the cooker to double socket underneath there is a 6mm cable.Also from cooker to CU there is 6mm cable and 32a fuse.How would you solve this issue?Thank you in advance for all the answers.
