Discuss Is this notifiable work ? in the UK Electrical Forum area at ElectriciansForums.net
NH0501
Seeking some advice - electrician has done 2 jobs - are either of these notifiable as he says he doesn't usually supply a certificate
1) installing new electric radiators - swapping out existing heaters and connecting up new ones to existing circuits
2) installing a power cable from consumer unit to an existing extractor fan.
Notifiable and warranting a certificate are two different things .
Exchange of like for like equipment doesn’t warrant a certificate (Minor works)
Replacement of the supply cable to an existing fan would require a minor works Cert. (non notifiable)
A new circuit for the fan would require an Electrical installation certificate and would be notifiable.
Thanks for your help - much appreciated.
(Beaten to it...)
1 - no
2 - sounds like new circuit - so yes
Supplying an installation certificate and notifying the work are two different things by the way.
Irrespective of whether he told LABC, the 2nd one should have an Electrical Installation Certificate.
Thank you - much appreciated
Reply to Is this notifiable work ? in the UK Electrical Forum area at ElectriciansForums.net
Hi. A few years ago we had a full house rewiring done by an electrician who issued a certificate for the work. He also left in the consumer unit...
Seeking advice, we have been replacing extractor fans for a local council and was originally told no ‘like for like’ replacement works needs a...
Hi, my niece lives in a flat and has a bathroom without a window. There is an extractor fan which packed up and an electrician installed a new one...
Hi guys, I have supplied my Shed with a 6mm SWA cable into a nice consumer unit. In there I have a 6Amp MCB for the lights and a 16 A supplying a...
Help please! I need a Tesla Gen 2 EV charger fitted in my garage which is 22m from the consumer unit. My electrician is proposing to route a 6mm...
