Discuss Isolation switch vs RCBO in the UK Electrical Forum area at ElectriciansForums.net
tvrulesme
Planning a kitchen design with a 7.2KW induction hob. The hob will be on its own separate circuit protected by an RCBO.
Best practice seems to be to have an isolation switch for the hob but the ideal switch position would be directly underneath the consumer unit. Given that I would be able to easily isolate the circuit using the RCBO is there any requirement which would still call for a DP isolator for the induction hob?
Distance from the hob to the consumer unit is ~2.1m but I understand that BS 7671 no longer states a maximum distance of 2m so hoping this would be ok? Planning on putting a 10mm2 cable to feed this (slight overkill) so the fewer little terminals to terminate this in the better IMHO.
This will of course be carried out by a qualified electrician. I'm just planning and researching at this stage.
The idea of a local isolator is that if you’re cooking, and it goes on fire, you can quickly isolate the power to then tackle it safely.
If you get an electrician in, they will probably want to put in an isolator close to the hob, as it’s good practice.
Thanks for the quick response. So reading this, aside from best practice there are no regs that this would contravene? I'll almost certainly go for your suggestion but just wondering if the regs actually enforce it or not?
While you're right that BS7671 no longer states a distance, I'd still say that good practise would mean it is easily accessible and identifiable, which IMO wouldn't be covered by an RCBO amongst a bunch of others with small writing - especially for visitors or someone not familiar with the setup.
Table 537.4 in BS7671 does suggest that RCBOs can be used for isolation/emergency switching/functional switching - though not all RCBOs are Double Pole.
If the consumer unit is in the same room as the hob and not in a cupboard or likely to blocked with stuff, then a standard DP switch below it might well be a reasonable option, if it's not possible to have one more adjacent to the hob.
It is something that you will need to discuss with the electrician doing it though, as they may have their own idea of what's good practise or not and they need to be comfortable with what they install, regs or not.
David Savery article on this a while ago (he has updated it to current regs). It's worth a read:
Very interesting read and agree with his take. Mine would fall under:
"If you’re remodelling an existing kitchen that lacks one, fit one where practical if possible, ideally within two metres of the appliance and not closer than 300mm."
Decision made, I'll allow for this when I fit the back boxes.
Reply to Isolation switch vs RCBO in the UK Electrical Forum area at ElectriciansForums.net
Trying to organise a CU replacement at home. It's a 1930s property. It's got a 10way CU but with no RCD protection. Was after a larger unit with...
4K
Hi, I have received conflicting advice about Main Isolator Switches and would appreciate forum member's help to plan a way ahead. Looking to the...
Deleted member 155212
I'm planning a replacement for my existing domestic CU and would like to have it sanity checked before I get an electrician involved. The main...
4K
