Discuss Job to small to get a plaster out, what to use! in the UK Electrical Forum area at ElectriciansForums.net
Very good advice. Plaster board adhesive is great for setting boxes into walls where the background is weak or the existing plaster dodgy. Never tried mixing it with cement to be honest but might give it a go!
Don't mix Gypsum products with cement. They cause a chemical reaction and deboned.
This is not my field Dan but its common practice to add gypsum plaster to internal cement rendering or plastering its even used with lime and its known as gauging.
I have done this myself on the advice of a plasterer.
Meh, a plasterer lol
"a chemical reaction occurring between the cement based adhesive and a plaster substrate, a known problem know as "Ettringite Failure".
Preperation - Pva Versus Primers | Always Use A Primer When Tiling, And Not Pva - http://www.tilersforums.co.uk/threads/pva-versus-primers-always-use-a-primer-when-tiling-and-not-pva.2511/
We have chemists on TilersForums who make barriers to prevent this because it used to be such a common problem. Plasterers being the worst culprits lol
The interior of my house was stuffed up with care by previous use of PVA. Tiles all fell off the walls (exactly as described in the tiler's post) and one can peel the paint off the walls in sheets. The walls were plastered brilliantly and then given a heavy coat of PVA. The paint / tile glue never penetrated in any way and the wall reminds me of teflon coated fry pan for smoothness and non stick. Soooo much grief ...
Just had a read Dan have to say I nearly fell asleep. Just wondering why all the plaster thats on top of cement rendered walls has not fell off and plaster on brick and mortar, concrete blocks etc. Like I said I am no Expert in this field but live in a home now worried about all my plaster falling off :tongueout:
Because if it has been done right an acrylic primer would have been used to stop them mixing.
The two that don't mix is calcium sulphate and cement.
Cement based adhesive on calcium sulphate (gypsum) screed - http://www.tilersforums.co.uk/threads/cement-based-adhesive-on-calcium-sulphate-gypsum-screed.7346/
Happens on screeds, concrete, plaster and render and the fix is simple, buy a 12 quid bottle of liquid (primer) instead of 3 quid (pva).
But obviously that's more expensive than doing the whole job again inc thousands of pounds worth of tiles and whatnot.
Plasterers always being to blame usually. Sometimes a DIY tiler mind.
Either way, don't rely on anything you mix together that contains those two.
Blimey all we wanted to do was set a back box into a dodgy wall. I sand/cement rendered my sitting room walls and then finished with a topcoat of thistle board finish, lovely job even if I say so myself. 18 years later it is still looking great. Mind you not been in there for a week or so, probably won't be able to get the door open now for a pile of render behind it..........
Reply to Job to small to get a plaster out, what to use! in the UK Electrical Forum area at ElectriciansForums.net
Essentially I have a "normal" socket in a ring mains, i.e. one 2.5mm T&E going in and one 2.5mm T&E going out. I am looking to simply add two more...
Plasterer has been in this week and after leaving today, he left the light on in the room. I went to the room to turn the light off and saw the...
4K
Hi Everyone, My first post here, just a simple question. I currently get all of my work through word of mouth and contracts that I have...
Morning All I recently completed my first re wire and board change, (with help from the owner who is a gas fitter and plumper, who works with my...
